Looking at your avatar, I hope that's not your 400.1 on top of your box. They use vertical MOSFETs and are VERY VERY prone to vibration damage, if an output FET snaps off the entire amp goes up in smoke, $400 repair bills...
10.x volts fo' life!
My 400.1 is mounted onto the top of my box. I have nowhere else to mount it. I think ill throw like carpet or some rubber washers under the screws/ feet. I have no where else to mount it though. What would you recommend i do?
rubber washers will help but the whole box will still vibrate and the sound waves will cause some vibration.
other than the rubber washers, there isn't much you can do. you should be cool though.
Alright, i'll give that a try, it should work somewhat decent. I was also thinking about putting a floor under the amp. Like have Half inch mdf; put rubber washers under it, then put rubber washers under the amp as well. And see how that works out...
Thanks
thats a beefy little bastard damn
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 294 Guests (See full list)
