ive been debating on this one for awhile, does it really help running from the negative batt up front to the back with the ground? im trying my hardest to get as much power as i can back to the 2 2400s i have. Opinions? thoughts? im welcome to all
Thanks
Derrick
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
in my experience no. it is a waste of wire as long as the big three is done right
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
yeah my big 3 was done right, went from sitting at 13.4 idle to 14.0 idle guess im might be using this other 40 ft of knu 1/0 awg for power wire for the future LOL
Edited by Army_guy614
Team DC Audio
so would i be better off doing more grounds up front and more ground spots in the back? *up front being in the engine bay...* like neg to transmission and neg to engine a few more times?
Team DC Audio
as long as you have a solid ground it will not benefit you at all. if yourground is weak then gor for a ground to the bat
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Always test the potential at the ground location, dont forget that, dont wanna create a ground loop. Im not running as much power as you by any means, i ran 1/0 to my dist block, 4 ga. to the amps, 4 ga. from the amps to the ground block, 1/0 to ground it, and 1/0 from the batt ground to the chassis
Correct. You dont need to ground them at the same spot, just make sure they have roughly the same potential. I think mine both ended up within .05v of one another
