77-AUDIO Posted March 30, 2009 Report Posted March 30, 2009 I was wondering if anybody has done a wall using only 2 12" subs and if so how did it sound. I am going to wall my car once I get another car to drive. it might be a year from now but that gives me plenty of time to plan. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
Neo_frog Posted March 30, 2009 Report Posted March 30, 2009 Since you have time, I'd recommend getting at least two more and another amp. There aren't many rides that only wall 2 12s. I have seen it done though in some SPL setups with way bigger 12s in smaller cars. Usually they go with 15s or 18s if it's only two subs. As far as how it will sound, nobody can really tell you. It all depends on the type of wall. It will most likely be louder though... Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
uhoh_45 Posted March 30, 2009 Report Posted March 30, 2009 2 12s could do well walled in a car dont limit yourself to just a standard ported sealed wall... look into horns t-lines bandpasses and use all that room you have to build somthing bad ass R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Kicker Guy Posted March 30, 2009 Report Posted March 30, 2009 didn't pete from TTB have 2 13w7's in a wall? Think it was a horn and was doing 50's Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz
ptcary Posted March 30, 2009 Report Posted March 30, 2009 Well......if your gonna give up the whole back of the car, you might as well go at least 4 to 6 subs, 12"s or 15"s! If I can squeeze 8 12"s into a PT.............. What kind of car do you have? PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
camino_1to3 Posted March 30, 2009 Report Posted March 30, 2009 Since you have time, I'd recommend getting at least two more and another amp. There aren't many rides that only wall 2 12s. I have seen it done though in some SPL setups with way bigger 12s in smaller cars. Usually they go with 15s or 18s if it's only two subs.As far as how it will sound, nobody can really tell you. It all depends on the type of wall. It will most likely be louder though... Didn't even ask what the vehicle was, ingenius. Neo: Fail PT: Team T3 Audio Team Sundown Audio Team O.B.M Operation Beast Mode "Believe half of what you see and none of what you hear" wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
Neo_frog Posted March 30, 2009 Report Posted March 30, 2009 Didn't even ask what the vehicle was, ingenius.Neo: Fail PT: Heh, hardly. If you're going to wall 2 12s, chances are you are not driving a Tahoe. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
