I got 2.039 cubic feet or 3523.813 cubic inchs with a port volume of 961 inchs. The port width is 2 inchs and is tuned to about 34 htz. I used the RE box calculator. The box is for 1 Dc lvl 3 and will be used in a T line enclosure, this is for one of the sides. And do you think ill experience any Port noise? My 1st box had a 1.5 inch port and has no port noise, but this will push more air. Any suggestions would be apprieciated.
That's enough for 2 cubes.
How exactly is this going to be part of a T-line??? I don't understand.
I think im doing it right. I made the width for the box 20.25 on this "box" so i can tune it right. And then the other side has the width of 18.25, so each side where the sub is 18.25 inchs and a 2 inch port. for a total width of 38. Is that right? And do you think i will have any port noise? with that width of port? 2 lvl 3's will be in this box.
print screen your re box design so we can see what your design looks like
R.I.P!
(Nov-29-2009)
92 explorer
current build
its only the L design i cant find a program to make a T line. But its the Re Box calculator. Heres what you have to type in (dont have a printer with ink)
Width 20.25
Height 17
Width 1+2 17
Port width 2
Port length L2 13
I can't really tell what you are describing, but it isn't a t-line.
Its like Port in middle, sub on either side of it. I thought it was called a T line cuz the port is like a T, but idk but you think it would work?
thats a ported box.
a tline has a huge port that is around equal size of the woofer in square inches i believe its a few FEET long.
or sometin like that
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
