Sounds like a speaker issue, not an amp issue. The speaker could be on its way out.
What ohm load is it wired up to? Make sure its not at like .5 ohm or something.
Its wired to 1 Ohm i gues the Giagram I got is 1 Ohm 1 wire goes from the Negative on one post to the other negative on oppasite post and same for the positive then I got the Negative hooked to the left side and the Positive hooked to the right side and running to my amp so 1 ohm right ?
same thing happened to me like a month a go, fried a couple cells in one of my rear batts, fucked everything up, replaced batt, good as new but it was cutting out just like you explain.. so just check your batt voltage with a dmm too just to be safe, and most likely it's just that 8 gauge wire you're runnin
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
wire is way too f#$%*@# small. in your case, its like trying to get a cadillac through a dog house, knukonceptz wire kit isnt too exspensive, get one. are your RCA wires beside your main power wire? that might have somehting to do with it.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
Does this skipping happen on every songs you play or just some of the ones that high bass response?
  • 11 years later...
Idk what’s going on with my sounds, I have two batteries and a voltage meter when it drops down to 117 it will cut out. What do you think I need a new alternator or what, I have a 150 watt fuse as well and 0 gage! Let me know something!!!
  • Who's Online   0 Members, 0 Anonymous, 607 Guests (See full list)
