Posted (edited)
hes knows what he is doing?
the port is the most important thing in a ported box. wtf!
Edited by brewer_brewer
im sure someone can give u a good box design, all u gotta do is ask xD. if it where me i like bigger boxes, id do 3.5-4cu^ft tuned to 35-38hz. ive had good luck with slot ports, there is a box calculator somewhere on the web that u can put in your max dimensions and it will give you a layout of all the sizes the mdf needs to be, it also allows you to adjust tuning. google re box calculator to find the calculator. good luck xD
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
Posted (edited)
the recomended size for a ported enclosure is 1.8 cubes. 4 cubes is way too big for the space he wants to take up.
i did a new design for ya. want the cutout list, or do u want me to modify the old box's shape a lil? this one is tuned to 33 hz, i thought the freq. responce was 40+ not 30+
the cutouts on that are the same size that would be on an actual box.
Edited by BanginOnABudget
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
All that MDF making up 2 seperate chambers , why not design it simple like Boon's ?
One face with 2 subs and a simple single L port .
2000 Trans Am ws6 - 6spd / M9 / cam / full bolt-ons / semi full suspension / tune
1998 Integra - daily beater, [2] AB XFL-1244's / 4ft³@35Hz, 61in² / Saz-3500dv1 @.85Ω
Posted (edited)
What do you mean about modifying the old box's shape? I'm lost...lol
EDIT: I would honestly rather build this box since I don't trust myself to be able to make those 45 corners...
Edited by ktownsdriftking
Too many projects, too little time...
