What would happen to your rides if you didnt have any.
just seems like a thing to think of if you didnt install deadening products.
i guess it just depends really. if you have a small system, it won't do much. just make it where there is no rattle and a bit louder inside. now if you have a bigger setup and you want DBs, then it helps with DBs and to make sure you don't tear your roof apart like some people. so it just depends on the setup.
1994 Ford F150 reg cab
2 HFX 12's
Audiopipe APSM-1300
i meant along the lines of, what damage would your personal car get if you didnt have dynamat. thanks for the info, helps in understanding what it does to sound.
your car will rattle
R.I.P!
(Nov-29-2009)
92 explorer
current build
and X3
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
Cos' you've installed so many systems and done so much dynamatting... :01nocomment8so:
Less rattles, sometimes less dB, especially in Street class cars.
Primarily I just use it to improve the midbass from the front speakers. Otherwise when it's cranked it's going to rattle regardless...
10.x volts fo' life!
I haven't installed any type of deadening except like 5 pieces of duct taped stacked on each other to put on the a-pillar because it was pissing me off so much but it seems for my tahoe it would stop the plastic panels from flexing against the metal and making annoying sounds.
it also acts as a weight in some cases so it is harder for bass to flex the metal.
Wouldnt be thehoe92 without teh purple
and X3
& X4
dont know about 'damage'. as stated before, if your system is "small" the only thing thats going to happen is annoying rattles.
personally, i suggest investing in some type of sound deadening material
TNCB
....my damn room was shaking, im like wtf is this how am i gonna die jakin off to vida guerra?
  • Who's Online   0 Members, 0 Anonymous, 3164 Guests (See full list)
