need best way to prep mdf to be ready for paint
dude id say just sand it smooth then maybe use a heavy coat of primer to fill in all the little shits and scratches then your good
Sand it really well....primer it with few coats of high build primer, sand and paint (be sure to wipe it down and make sure its free of dust and debris).
Edited by wL<3bass
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
im trying to minimize the amount of work a shop will have to do cut5 my costs i got quoted at 800 to 1000 to paint my box im not paying that much lol
to let yall know i dont have a spray gun so how would i apply primer
yall wouuld use resin
Edited by MATTMAN24
Do all the prep yourself and have them paint it....I'm assuming your having them use automotive paint...otherwise if they are using spray paint (rattle can) then I would do it myself.
My YouTube Videos
in my experience KILZ primer really sticks to mdf without even sanding it, (even the edges of mdf).
but of course if you want a smooth finish you have to sand it a lot
Ok heres my input, I resined the front of my box for a lil extra strenth and the rest just left alone n primered, when I painted it i noticed that the resined front the paint stuck alot better, especially the edges, the edges on the untreated MDF i had to put 6 or 7 coats of primer just to get all the wood color to go away, and still paint wouldnt stick, especially white, it would litterally soak it up as soon as i sprayed it on there, so i would say, put a nice even coat of resin over the entirety of the box, sand all of the rough edges, bumps, etc.. down with a heavier grit then resand with a fine grit to keep it smooth, shoot it wth a coat or 2 of primer, sand, paint, n 2 layers of clear.
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
When I paint MDF, I use Scherwinn Williams Pro-Cryl Primer and Sher-Cryl Paint. Only takes one coat of each, but it's like $70 a gallon. It's for industrial use only with no hardener so it's convenient.
Need an install? Hit me up.
[email protected]
  • Who's Online   0 Members, 0 Anonymous, 892 Guests (See full list)
