Spare Tire Well , First Time Question
"sanding the wax off" between layers is a waste of time IMO.
I have known about the wax in some resins...even some that I use...and never bothered with sanding anything that didn't need it for aesthetic reasons or to smooth out airflow over a surface...and never had an issue with it.
Roughin it up wouldn't hurt and should help with adhesion between layers but seriously In a spare tire well it has the spare tire well for support along the outer/bottom surface so it doesn't even really make that much diff if the layers are perfect or not. Just build it strong, and "clean it up" where folks will see, but don't kill your back bending over the trunk to sand something that really aint gonna make a lick of diff when it's all said & done...maybe some OCD/GP2k2 peace of mind knowing it's "perfect" between layers....But I would just throw a few more layers over it and make sure it's plenty strong. Thats what'll really matter.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
if you taped the tub and glassed over the tape once the first coat is hardened you should be able to take it out and work with it outside of the car so you dont have to hurt your back any more
R.I.P!
(Nov-29-2009)
92 explorer
current build
the wax is in the resin, not just the top of the layer. if you work with a bonding resin you will find out it is almost impossible to sand the sandpaper will stick to the resin instead of straching the surface when sanding a resin with wax in it
I'll be damned, I'd never knew that/ or ever had that happen. Eh, eitherway, the way I work with glass is tried and true, so I'll stick to it. :)
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
LOL at the Timmy joke
Roseville, CA
thanks again guys , i pulled the tub and it seems fine (actually looks good lol.) just going to start laying on some mat and make it nice and strong and than back in the trunk we go . i just want to say thanks to every one who gave advice it is very appreciated .
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
  • Who's Online   0 Members, 0 Anonymous, 1888 Guests (See full list)
