6.5cuft Run Fi15''btl Or Fibtl 18''
Hey guys, once again im stuck on making a dicision on my truck during the build. i did some detailed measurments and turns out i have 6.5cuft to work with after displacments. now i was going to run the FiBTL15'' but seeing how i have 6.5cuft, would it be a good idea to run the 18????
which one would give me better bass and loudness. i dont care about SQ mostly SPL.....
would it be better to run the 15'' at 5cuft, or to run the 18'' at 6.5cuft.
thanks guys for the advice
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
yeah audioque 3500d, be pushing 3000rms when im showing it off. daily around 2,500rms
1 3500d AQ amp
Two 15's would be better then one 18.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
If your open to other brands a custom Nightshade 18'' would work perfect in 4.5 cubes. If your stuck on FI I would definitely get 15'' as you probably won't have enough room for an 18 after port displacement.
Drew
Ref's include: sundownz, army-killa, queball, wildsebring, foshay1123, greenman100, loud-n-low, acex3a, circa40, orangeless, PBateman,xtcxyooj, chaunb3400, oldschoolboomer, SPLluminator
18s can run fine in 6.5 cubes... :rolleyes:
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Drew
[/quote
i havent had much experiance with nightshade. ill have a solid 6cuft when everything is said and done with everything. I can go ahead and say this, "i only do 1 18 or 1 15'' behind my seat because i dont put a woofer behind my Girlfriend (soon be be wife) seat. so another woofer it out of question.
1 3500d AQ amp
Thought he said before displacement, reading>me. :01nocomment8so:
Drew
Drew
read my first sentence i wrote. i say 6.5 after displacements and everything. then later on i said 6cuft would be the minimum i would have if i had to cut back a little
1 3500d AQ amp
  • Who's Online   0 Members, 0 Anonymous, 2107 Guests (See full list)
