base x height x width / by 1728 i belive will work
must be nice huh
you need to fill .19 cubic feet?
pfft some people wish they had that much extra!
5x6x12 is around .20
Edited by tibs
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
so like a 2x4 thats a lil over 17 inches should work by the wat that formula is base times height times width divided by 1728
must be nice huh
use a 4x4 and cut it to length. 4times4timesXdivided by 1728 equals cu.ft. displacement.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
4 2x4s 15" long takes up .18
R.I.P!
(Nov-29-2009)
92 explorer
current build
thanks uh oh lol
must be nice huh
.....wtf is that ur using? i hate math, that looks easy
My Babies
97 2.5 Avenger, 92 5.0 Fox, 97 2.0 Turbo GST Eclipse, 00 2.0 Jetta, 06 GSXR 600, 98 CBR 600, 01 GSXF 600, 93 CBR 900RR
Wilwoods dont slow your car down, they slow the earth down under your car...remember that next time you slam your brakes, you may spill my drink.
  • Who's Online   0 Members, 0 Anonymous, 2273 Guests (See full list)
