I noticed with my setup up everytime i added a 2 more batteries my lowest voltage increased bout .2 tenths..and also when i was on 16v i only had 2 hc16v's and my voltage would start at about 17.7 and drop to 14-13.8..but thats only 2 batteries and they werent group 31 either..
i would get 2 more hc2400's
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
chode, chubby has a point. what happen to your t4k?
It fried due to voltage drop.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
negative..not this time
something came loose inside due to vibrations and i hat to hit the amp or a good bump to get it to kick back on...only to cut back off on a major bassnote.
voltage was fine stayed at or above 12.6...
when im driving it stays in the 14s to high 13.7-13.9
when i let off the gas and its a HARD bass line ill stay above 12.9-13.2...mainly while driving with good bass it stays around 13.9-14.2 but when i put it in park or neutral she likes to drop...driving is different...i dunno why
because when you're driving you have more RPMs meaning your alt produces more allowing more current to produce higher voltage.
but when in park i rev around 1.5-2k and i still drop to mid 12s...yet while driving and keeping it at the SAME RPMs...the voltage stays up a lot better
NoFearX18 said:
o.O that IS weird...
yea....but at times it will drop a lil lower but thats on real heavy notes...soemtiems it stays in the low 14s...soemtime in the high 13s...ocassionally in the 12s
but more in the high 13s
NoFearX18 said:
trainman0978 said:
I have a 220 amp alt stock batt and a z1 at 2 ohms and I rarely dip under 13?
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
