Ok currently running 5 amps(ones in my sig), 2 sub amps, 3 four channels...of an alpine 9886 with 2 sets of normal preouts, and one set of sub preouts...all 4v. Right now i have them ran into the input on one amp and then the preout from that amp to the next...iff you get that. So basically im using the preouts on the amps alot...how bad is the voltage gonna suck being split up that many time?
Would it help to look into a line driver or something along those lines?
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
it might help looking into a line driver, but, when i was running all my JL amps i had three 500/1 daisy chained together and didnt have any problems.
Are you experiencing any problems?
2007 Acura TSX
Stock Navigation
Rockford 360.2 (FOR SALE)
Sundown SAZ3500
2 12" DC Sound Lab LvL4 @2ohm
JL 600/4
2 Sets of Focal 165K2P
a line driver, or EQ with F/R/S outs with a specified voltage would be nice. Worked many times for me
but you are losing signal strength splitting it that many times, there should be more potential than what you are hearing now
Ok i dont really know much about line drivers but it looks like they put out around 8v...my alpines are only rated at 4v max input...am i going to hurt them but giving them 8v?
Systemless.
i have heard/read that putting to much output voltage to an amp can burn it up.
meh depends on the amps input range.
DC.jpgDC POWER
If your head unit Pre Amp is low, and your slpitting it that many times, u need a LINE DRIVER!! one from sound stream would be fine, and u can set the gain on the driver so it send a STRONGER RCA signal in which the signal will carry through all of your AMPS...
Edited by SubSonic
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
Just use the gain on the line-driver to set it so you only get 4v to all your amps. 4v is heaps. If your amps are only rated to 4v and you stick 8v up them you risk cooking the input circuitry.
10.x volts fo' life!
Don't see how your loosing much by doing in and out of amp... Should be same signal... If you split one side to amp and the other to another you will loose but.. Also most amps with take up to 9v preout voltage so 8v is pretty safe.. You will still see improvement in 8volts positively
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
