dr hypothesis Posted May 21, 2009 Report Share Posted May 21, 2009 First time being on a meter in a number of years. King of dissapointed in the results, though there is some stuff I know that is keeping the score down. Windows down with car on, sensor on the windshield, I played some test tones off of a Bass Mekanik cd. I was averaging a 150.3 from 35hz to 45hz. Windows up the highest was a 147.6. Charging was just from my alt and was doing a bunch of burps. Tried a Usaci street beat style run, and only did a 144 with the sub level on my deck turned all the way down (first run i tried, forgot it was down low), tried it with level at my normal setting and he screwed up the start, so we just tried burps after that. My port is on the passenger side (don't ask, had originally planned to put it on the drivers side). This is from before it was all the way sealed up. Box is 14 cubes, 35hz tuen, 192" of port. More power, bigger alt, another d3100, maybe some more port area, are probably in my future. This thing does such awesome hair tricks, I thought it would be louder. 2001 Chevy Impala Eclipse CD7200 mkii Cactus Sounds 5kw Sundown 100.4 (2) Fi BTL 18s (walled) ID 6.5s (2 sets) Iraggi 320 amp Alt XS Power Batts KnuKonceptz Wiring MidwestSPL Scores: 152.0 Advanced 2 136.1 Extreme 3 Link to comment Share on other sites More sharing options...
bassbaker15 Posted May 21, 2009 Report Share Posted May 21, 2009 Damn man, sorry to hear that. Looks like its louder than that as well. My truck does 144.8 street style and 150.4 on burps. Kinda diapointed me as well, I kinda said screw the meter im happy with it. Team Deadly Hertz 1997 GMC 1500 Update.... System is gone Motor is fucked Truck is down and out for a while Myspace YOUTUBE My Build Link to comment Share on other sites More sharing options...
wL<3bass Posted May 21, 2009 Report Share Posted May 21, 2009 Port on drivers side, more power? alt? and more port area. If your happy with it no need to change for the meter. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references... Link to comment Share on other sites More sharing options...
Nightshade Posted May 21, 2009 Report Share Posted May 21, 2009 I wouldn't reccomend adding any more port area, if anything less. I would put the port on the drivers side like you said though. That is probably worth a db or two in it's self. I would try a smaller box size too but this is all just my opinion. Maybe something in the 10 cube range with 130-135 sqin of port. I would almost bet that would be much louder than the size that you have now, but unless you try it we'll never know. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz Link to comment Share on other sites More sharing options...
Boon Posted May 22, 2009 Report Share Posted May 22, 2009 Wow, yeah those numbers are well under what you ought to be pulling. I'm getting similar dB from 1 15" 10.x volts fo' life! Link to comment Share on other sites More sharing options...
dr hypothesis Posted May 22, 2009 Author Report Share Posted May 22, 2009 This is just my daily driver. I would say I'm content right now. I won't be able to do much upgrading tell early next year probably, but my goal is to be able to do a 150 with music (windows up or down). Probably would be damn close or there with the port on the drivers side. Don't want to build for metering, just the loudest daily groundpounding I can. I'll probably just go up to 5kw or 6kw, shrink the box size down a bit and try to tune a bit lower as well. 2001 Chevy Impala Eclipse CD7200 mkii Cactus Sounds 5kw Sundown 100.4 (2) Fi BTL 18s (walled) ID 6.5s (2 sets) Iraggi 320 amp Alt XS Power Batts KnuKonceptz Wiring MidwestSPL Scores: 152.0 Advanced 2 136.1 Extreme 3 Link to comment Share on other sites More sharing options...
onlyinajeep Posted May 22, 2009 Report Share Posted May 22, 2009 id say that is awesome for being tunned so low my 2 18s didnt do much more than that and that was double the power TEAM PURE Team South http://www.stevemeadedesigns.com/board/topic/195192-8-pure-audio-15-flat-wall-chevy-crewcab-dually-vid-page-4-s/ Link to comment Share on other sites More sharing options...
EricR Posted June 8, 2009 Report Share Posted June 8, 2009 looks good man. a little more power, alt, and put the port on drivers side and you should be golden. i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work? Link to comment Share on other sites More sharing options...
EricR Posted June 8, 2009 Report Share Posted June 8, 2009 btw, do you have any build pics of this? i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work? Link to comment Share on other sites More sharing options...
