so ive been thinking about the wall thing.... and doing say 6 12's..... i have a 93 chevy lumina 4dr.... and i dont even know where to begin... what are the steps, procedures, tools, and anything else to know about building a wall?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
well i see the walls but its a finished product and shows me nothing about it... i guess i should look at wall builds....ugh more research time....
3 Kinetik Hc2000's
Dual 200amp alts.
.... Ugh
post the info you find Please! id like to do one too.
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
give me a minute ill get the links to my build of my wall and it shows somewhat (you should get the idea) .....
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
reasearch is the best way to go . there is no set way to build a wall every car is differnt but by looking you will gain alot of ideaas
Edited by vexproductions
scrool down and you will see the finished front of the wall, and how the box is blue and atop the box is black then the balck roof. ,.,,,,.... that was done to seal off the top and same was done on the sides of the wall...
then further down you will see 2x4's going from the top of the box to the roof of the van to help brack and hold the box down. and then back filled with expandafoam... that was done to finish the seal off, but remember to properly lag/carrage bolt the box to the floor of the car last thing you want is to have it land on your neck in a accadent.
http://www.stevemeadedesigns.com/board/ind...=7757&st=40
Its the same as building a box, just bigger :)
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
many methods to building a wall so it depends on your budget, skills, tools available, materials available, and your goal.
My method is no where near like building a box just bigger.
Some use 2 x4s and frame it out, then add MDF or Birch, much like building a house.
Some weld in a steel cage then layer up the wood.
If you wanna do my method you will need MDF as a form, and alot of fiberglass resin and sand, and alot of 2 part liquid plastic.
Some use concrete to pour around the box and fill in the floor.
So do research and decide what is best for you.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
