Reason Why My Amp Went Up In Smoke?
bennett15
Im still trying to figure out why my brutus
went up in smoke. the only thing i did diff. was
changed the ohm load from 1.6 at the amp to .7
the amp is 1 ohm stable. it ran for about 2 mins
and i could barely hear anything from the sub so i turned
the volume up more and it sounded like it went into protect and out a few
times? then i looked back and it was smoking a lot. Amp still turns on and no
fuses were blown but it stinks like sh*t and sub doesnt even get a beat to it?
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
Your output section is fucked most likely.
Do you really need to ask the question? The reason it blew is because you tried to run it at 0.7 ohms. Doesn't sound like your electrical is up to much either based on your sig.
10.x volts fo' life!
yes i do actually the amp is only 4 months old. and .7 ohm after the box should
have been fine with box rise on a 1 ohm stable amp. And i have a stock 130A alt big 3 in 0/1
and a rear batt volts dont drop pass 13.8
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
when you wire dual 2ohm subs which is really (1.4ohm) per coil it wil read as 0.7ohms.....and it shouldnt have smoked unless you were dipping to low in voltage......or your gain was cranked to high.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
i didnt touch the gains or anything i had everything taken out i was re-doing what the sub sits on
in the back of my truck. get everything back in re-wire the sub checks out at .7
hook everything up to the amp. start truck start playin a beat not hearing anything from sub
turn it up a bit louder amp goes up in smoke but still turns on.
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
anyone else?
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
you are guessing that box rise put it at 1 ohm or over...
did u set the amp correctly with an o scope?
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
no it was set with a dmm a few months before i dont see
why going from 1.6 to .7 would make it smoke instantly
sub never even played
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
