Reason Why My Amp Went Up In Smoke?
bennett15
if its a dual 2 how could you have wired it to 1.4 or 2 ohms in the first place? only used one coil?
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
no sound at all even off the bat seems like one of the coils were reversed. normally the speaker would blow first, but i don't know anything about that amp.
^^ Ding Ding. My money's on one coil wired backwards which will typically send an amp into protect but could very well lead to letting out the magic smoke.
only used one coil?
Ive seen this a lot, but more then that Ive seen people wire up 1 coil to the amp correctly and on the 2nd coil they just connect the post and neg together.
Normally when they connect the coil like that the sub and amp will still play somewhat normal at low to mid volumes, and go protect happy at a higher volume, and sooner or latter risking a blown amp.
guessing thats what i did because i had it in series then wires going to the box i just used the + and neg on
just one coil when i should have took the + from one coil and the - from the other?
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
its was the 1600 and 08 model 25th aniversarry
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
Posted Image
this is how i have it wired rite now and at the amp i get a 1.4 ohm load
when the amp blew i had - to +, - to +
then from just one coil i had a wire coming off + to box and wire of - to box
and at the amp it read .7 ohm then the amp smoked up when i tested it out.
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
when wired like in the pic it should be the .7 or 1 ohm load. how u wired it when the amp blew is some nonsense that doesnt even exist hence blowing the amp
You had it wired to a dead short. Where's a face palm smiley when you need one?
  • Who's Online   0 Members, 0 Anonymous, 1235 Guests (See full list)
