Almost sure it's my A/C compressor... Here's a pic of the steering...
cant really tell from the pic but it looks like the ac comp
I know a lil about everything so dont call me Mr. Know it All.
turn the ac off, look at the component, then turn the ac on (with air on obviously) and see if it looks different.
ac compressors have a clutch on the front that doesnt spin when the ac is off, but is on when the ac is on.
that is your water pump if you want to know where the ac compressor is get a haynes or chilton car manual for your car. it has anything you would want to know about your car
Edited by Boomin660
Find out where it goes too, if it goes to your steering rack, then its your power steering pump, if its your A/C compressor, then lines will be running to your radiator up front. Cant really tell form the pics.
Definitely not the ac compressor...that is usually a large unit with two metal lines coming off of it.
Doesn't really look like power steering either because that should have a metal line off of it too.
I'm with them..most likely water pump.
x3 on the water pump.
In the first picture you see the hose coming out of the back? If that were an AC or power steering hose, it would have a much stronger fitting than that little metal clamp type one. It would have a compression fitting or something b/c of the high pressures that an ac or ps pump put out. Water pumps just cycle the water and therefore don't need the really strong fittings.
Just follow the hoses like wierdguy75 said.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Do you have a diagram on the top of your hood for the belt? Most do, and it will tell you for sure which one it is
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
