of course, i want it to be heard from far away with windows down of course lol, keep the sound in with windows up
1 4" wide aeroport or a 4" wide slotport?
A single 4" tube/aero port is FAR too small. You need more like 4 of them, or 1-2 6" aeros depending how much power you have and how you want it to sound.
10.x volts fo' life!
for every 1 cube the box is after displacement you need a 4" aero port at a minimum
here are the dimensions re box calculator gave me so we are on the same page....sorry im new to box building, will this work for 1 15" BTL....supposingly, itll fit in the trunk(s) of the newer car(s) im trying to get (97 Honda Civic EX, 97 Nissan Maxima GXE
Box Width: 35
Box height: 18
Box Top/Bottom: 22.5
Wood Thickness: .75 (except the double baffle in the front= 1.5)
Square Port Height: 16.5
Square Port Width: 5
Square Port Length 1: 16.75
Square Port Length 2: 10.75
Total Port Length: 35.75
Square Port Diameter: 10.249
Square Port Area: 82.5
Square Port Volume Internal: 2949.375
Square Port Volume Displaced: 2969.4375
Box Volume (Ft^3)= 4.999
Box Volume (In^3)= 8638.3125
Tuned Frequency= 32.05898
inside will be fiberglassed (not the port)
Edited by obcaraudio
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
check out my new post and maybe itll be easier to understand cuz im new to box building lol
Team gg.
I don't agree with that at all. I have a 7.2 cube box with 6 4" aeroports and my setup is well into the 152 range off of 3400 watts. That is exactly 10.46 sqin per cuft and your suggesting that you need at least 12.56sqin per cuft when using an aeroport. Aeroports are much more efficient than a slot port and require much less port area than an acutal slot.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
You know what, First off I take back the "at a minimum".
I meant it to be a general rule.
Trying to combat his single 4" aero for 5cuft.
In all honesty I use 1 6" aero per cube on big woofers
and for aero's being more efficient than slot.. I know that...lol
Since were bustin' balls here..
but your sig says
151.2db @ 43hz legal in competition
lol.. haha
:drinks:
k
Team gg.
