That question has been answered several times I even told you what to do and you keep asking. I did 147.7 at the dash with a single 12 and 4200clamped watts on the TL, seriously man its not that hard. Subs up port back, 4-12s would be more cone area then the 2-15s just get somthing and build then test, Im sure you will be close if you just try. Jeremiah ledgerwood did 157.1 on 30seconds of music in his explorer back in 2006 on the tl usaci style in the kick...painful to say the least.
Edited by jmanjr82
well i did the box for 2-15'' got it done this is the box i have--41''w--18''tall--26''deep----the port is -3.5''tall--27''wide--18.5''deep---i will have it wraped up today and installed and will see how is sounds----i did do the box with a removeable port so i can tune it -up--are-down-----i am going to do a box for 4--12''subs and see what works best in my explorer --dont no which 12'' subs to go with so i am looking at some-12''s--let you no when i am done with it i now someone with a--TL--so i will see if it hits the 150.0 if not i will try the 4-12''s thinking of runing the old m3 mojo subs but i dont no
Derrick824 is doing a 151.something with two 15's and ONE Saz-1500 in his Expo.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
well it is loud very loud--dont no if its doing 150.0 but it is loud--will put it on the -TL- on monday after 5.30pm when the shop is closed--then i will tune it some more and change the-- port --out and see what port dose what--i did -3-ports-one for the street-and- two that are- tunded to--40hz-and-43hz--will see what it will do and let you no--i may change my amp out and try out some of the other amp and see what thay do---will put the- AB-vfl-500.1 -on it first
its easy to break a 150 in an explorer
just gotta wall it :D
2 15s and 2 alpine mrd 105s or somthing (1000 rms each amp) did a 150.4 at 42hz
R.I.P!
(Nov-29-2009)
92 explorer
current build
i will do a 150.0 are better and i wont need a wall to do it--- i like my back seats i have a 4door and wont to keep all my seats why would you wont a 4door if all you are going to do is wall it off and make a 2door out of it---and what kind of sub are you runing i see a -FI--and a -ATOMIC--]]]]
both atomic apxx's just 2 had FI caps on
and cause its loud as shit so its worth it
R.I.P!
(Nov-29-2009)
92 explorer
current build
the good news--got to put it on the -TL- did a-148.3--at 38hz--one sub up in smoke-did this with the 40hz port after 9 run's on the -TL--at full tilt--and runing the AB-vfl-500.1 at--.75ohm's-- still cant find the dustcap from the sub----and i think i will try a new set up new box and subs --any one no of some good 15'' subs that like-2000-2500-rms ea let me no---i will call the man that did my subs and find out whats up with a new set but mite go with something new-----did not get to put in any of the amps i had with me--2-ab-vfl-200.1--or the -dd-z1--maybe next time---let me no what you think and any help you can give me now---------and up in smoke is not a good thing at all---
  • Who's Online   1 Member, 0 Anonymous, 1843 Guests (See full list)
