DC Sound Lab
sub closest to the port has no cone control and tends to over exurd and ripp suround
That's why I suggested the syle of box that I did to him.
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
only problem is with that style of box it wont be as loud (on the tl) as subs passenger side port driver and tuning it to 32hz he would not be burping a 152+
R.I.P!
(Nov-29-2009)
92 explorer
current build
Ever thought about plugging the port a little and throwing some bricks in the back of the box to decrease volume and keep the tuning the same? In my experience the score always decreases slightly when the sub starts to unload... Less port less volume = more cone control = maybe increase in score? Would be easy enough to test...
10.x volts fo' life!
not doubting your knowledge tooshort, unless there is proof you are willing to present, it isn't a fact or no once can believe it is a fact unless proof is provided. Yes that kind of flared port can be loud and be clean sounding(ik cause I've done a few boxes like that) but there is never ONE correct way to do a port. Different ports work for different boxes.
Bills
as well as different subs, power, and vehicles...
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
yeah its all different but its all through trial and error !
you never know until you try .... live and learn its all the same.
there is nothing such as the perfect box or the perfect port.
but its all worth a shot :)
95 Civic Coupe
Memphis 16-MCA3004
My 2 cents every multiple sub setup I had worked well in a common chamber with the port in the middle every time I ran the port on 1 side I always had 1 sub moving differently now 1 sub setups that's out the window however whatever you decide good luck and keep on truckin I love seeing your vids.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
ur sig KICKS ASS!
hahahaha :spiteful:
ur sig KICKS ASS!
hahahaha :spiteful:
You can tell he added the text himself. lol, he has a space between his words and the "!" =P
All his posts have it too.
  • Who's Online   0 Members, 0 Anonymous, 1756 Guests (See full list)
