Noob Question?
ok i want to run 2, dvc 2ohm subs on one amp thats 1ohm stable. like most mono block amps it has 2 sub channel outs. now can i run each sub in parallel to bring each sub to 1ohm and just hook one sub to each of the 2 channels?
You can look on the Rockford Fosgate site and they have a thing called "Woofer Wiring Wizard" and that should be very helpful.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
yup, www.the12volt.com has one too just wasn't sure since its mono block amp has 2 channels so wasn't sure if i could put 1ohm to each of the speaker outs and still have the amp at 1ohm
What your confused on is how there is 2- and 2+ outs on the amp. If its a mono block, each + is the same, and each- is the same, its just distro blocks in the amp. makes it easier to wire subs. supposed to be dummy proof
