i am wanting to run an audioque 2200d to a Fi BL 15" at 1 ohm - 2200 rms
and i was wondering if this electrical setup would be fine
mechman 250 amp alt
kicker 1/0 gauge wiring throughout
BIG 3 done in kicker 1/0 gauge
kinetik 1800 in front
kinetik 1800 in back
Edited by bass_addict07
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
well if i down grade to a 200 amp alt
and a 1400 in the nacl would that be enough
in yalls opinion what would be a perfect setup for 2200 rms?
honestly, biggest alt that fits, optima or hc1400 or something under the hood, and a d3100/khc2400 in the rear
i'd rather not have to worry at all....if you think "eh its probably enough" its probably not
Team DC
yah true im just trying to stay as cheap as i can
I wouldn't want to go cheap on audio. It might fry and wouldn't last long. THe install you have should be fine on the electrical. I don't know if that amp truly do under-rate
honestly id be worried about blowing up the BL with 2200 watts :lol:
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
mechman 250 amp alt
i think you will be fine running that bro. if you can throw a HC2400 in the back instead of a HC1800 that'll work too. That 250 alt will keep up with that amp with no hesitation.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I have that amp. It'll do 2200 if it gets enough power. I have a Hc1400 under the hood, and 2 Hc600's in the back, 136 amp alternator and a mild MLA module, (along with 600 watts rms for mids/highs; My voltage is 14.6 and drops to 14.2v at full volume.
I think what you have posted would be more than enough for a 2200D.
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
