Subwoofer Flexing Too Much?
ps6435
go get a DMM and use this to set your gains.... untill you do that this is a moot point to keep telling you what to do bro... just go check your stuff
*edit* you want to set your subsonic to 35-40hz, if you have it set to 70 then anything under that is pretty much free airing it which can cause damage to the sub...
Posted Image
his low pass filter is set to 70, not subsonic...if subsonic was it wouldn't play anything at all...The subsonic should usually be set at around 30 hz, depending on box tuning. However you are probably clipping like mad from the sound of it, so do what this chart says and tell us what happened.
A vitrolic, megalomaniacal sadistic psychopath.
i know the low pass filter was at around 70... and the subsonic is set to 24db but this amp lacks a bass boost and everything like some amps i have used in the past but i tried hooking up multimeter to it and i dont have a test cd but put a song where bass almost hits all the way through song and the multimeter read 19 at the way i had it set... i know your supposed to do what it says but i was just wanting to know what mine was currently doing...
realmofexcursion.com and go to music or downloads... they have the 50hz tone you need
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
it just sounds to me like your box is tuned way too hight.... get one built with a tuning frequency in the low to mid 30hz range... and you will be slammin on the lows.... imo you shouldnt have a box that is tuned 40hz and up unless you are burping...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
burning it now and i will test it...
ok i set the amp to where it said to stop around 32... which is like around 520 watts... and its at the same spot as it was before...
so i guess the problemo would be in the box...
can a sub bottom out because of the box?
yes...if you play under the tuning freq which ive said like 4 times.
510w? the amp can only do 400rms at 4 ohms bridged.
  • Who's Online   0 Members, 0 Anonymous, 3219 Guests (See full list)
