wire it to .5 ohm and set dmm at 27.4v
54.77v X 1/2ohm = 27.38v
And get naff all power when the impedance rises........
If you're running below rated impedance you need more than just a multimeter to set the gains.
10.x volts fo' life!
Sorry for a little off topic I dont want to make a whole new topic for a short question but I've been doing some reading and read that by setting the gain you are setting the RMS.
For example if you had 2 subs that could handle 1000w RMS a piece and the amp your using can only send 300 RMS to each. If the gain is tuned lower then the full your not giving the subs the full 300. Not sure if this is clear enough. or if this information is accurate just kinda wanting a credible answer. Thanks.
Old Setup
03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2
Highest Score to date: 151.2 db @ Headrest
Full gain does not mean full power. Even set to minimum gain you can drive any amp you can think of well into clipping with the right source attached to it.
"RMS power - 2 ohm linkable/dual mono 5400W x 1"
does that mean if i wire the subs up to a 2ohm load bridged that I can set the gain for 3k watts if Im careful??
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
no thats if your strap two amps togrther and as long as you have a decent electrical you will be fine with .5 ohm load and the xls can take a lot more power than 1500 watts
Roseville, CA
  • Who's Online   0 Members, 0 Anonymous, 1146 Guests (See full list)
