I have 2 P2 12's duel coil 4 ohm and 1 12 in 4 ohm sub
Can I temporary hook it up this way until I get 2 more P2 subs?
P2 12 @ 8ohms
p2 12 @ 2ohms
1 12 @ 4 ohms
according to the ohm calculator this would work out to 1.14 ohms
please dont bang me if this is a stupid question.. But I really need to know because I dont know :)
I am getting my T10001bd today and I need a temporary solution until I can get 2 more subs
Either that or I can go
2ohm
2ohm
4ohm
for a total of .80 ohm but I dont think the amp can handle that and I am not comfortable doing that.
I would like to use the full capabilities of the amp if I could
I could just wire the p2's at 4ohm but then I am only using half the amp.
Edited by Hotdog
I would hook the 2 p2s up @ 2 ohms ...and not worry about that 3 sub
Wouldn't the T10001bd smoke the p2 12's at 2ohm .. .I believe that is 750rms that would be 375rms for each and they are only rated at 250rms
at 1 ohm it would be 500rms each... that would fry them for sure
Edited by Hotdog
You can do it, but the power to the 3 subs will not be distributed evenly.
Brian
Current system:
Previous systems:
or you could wire the 3 to 2.6 ..if your worried about power on the subs
That is my concern there too much power for what I have for now.... Have to wait to get a couple more p2 12's to take full advantage of the T10001bd
so the 3rd 12" isnt a p2... in that case dont mix different woofers and stick with the p2s
So better off just running at 4 ohm? or how could I wire it to get the most out of the amp without smoking the subs?
Brian
That makes sense.. never thought of it like that
  • Who's Online   0 Members, 0 Anonymous, 1128 Guests (See full list)
