does the TL show the actual highest SPL, or the average of (39,40,41) if you are burping at 40...
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
Yes, its basically an average over a 3 hz range. The logarithms used to translate the pressure into a DB reading are apparently the most accurate in the industry. Doing it in this manner ensures a consistent reading no matter what the environmental conditions.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
If you could fine a song with all three freq's It may be able to bassrace higher than a burp? What sucks is seeing that big number on the RTA then seeing the lower average.... I have a little over 153 at 40hz. but my average is only 147.2....
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
are you talking about SPL or Bass Race??
1997 Astro
front:6 sets of T3 componets
Subs: 8 level 5 18"s (building 6th order BP)
Amps: 4 really big ones (totalling just shy of 50K)
Batts:
Alt: Ohio Generator
1996 Chevy Suburban
Sub amp: A fifth really big amp
Subwoofer: 2-15" DC Level 4 XL
Batts: C&D high rate--(x4)
If by average you mean over 30 seconds in Bassrace there are a lot of things that could contribute to that low of a score. One could be your start, if you don't start when the timer says "Set" your start will be late and will cost you score on your average. The other thing could be the music your playing. It could be the wrong frequency or it does not have constant enough bass throughout the entire song. If there is a break in the song you average will drop because of that, not because you aren't that loud.
For example I can burp a 151.3 @ 43hz. I can bassrace a 150.8 over 30 seconds with Lil Jon which is tuned to 43hz and is very very consistant bass. Now can you see why I was able to bassrace so high? It's because I used a very bass heavy song with no breaks and that song plays at my peak frequency of my car.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
No, Bass race is different. bass race is an average over time. A peak SPL setting or Burp score does not average over time, its an average over a 3hz range of peak SPL readings.
Ed Lester
ShowtimeSPL Host
My old Build Log
This is SPL burp..
Here are some pictures of my peak. At 40 I'am over 153 but with the 3 average, I'm down to 147.2, What can you do to fight this?
Second Question was, in DB DRAG if the had a song that stayed at 40, would it be possible to score higher in db Drag than burp? Since it doesn't average the three Freq, together
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
You cant do anything.
Thats the way the meter works, your score is 147.2 dB. You can work on your system to score higher though.
Everyone else is scored the same way. My 153.5 is the average over 3hz. My peak at 1 frequency is 159, but that is not my official score, 153.5 dB is.
Bass race reads the same way, but takes multiple readings over a 30 second time period and averages all the readings together. So it is basically impossible to bass race higher than your loudest possible burp score. You may be able to do the same score, but its very difficult.
Ed Lester
ShowtimeSPL Host
My old Build Log
Thanks Guys,
Now I understand more..
I was just wondering if there was a way to increase the output on the two other freq's...
I still have some more work to do, The blow thru is not sealed yet against the inside of the cab..
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
This is the new power... all testing so far is at 2ohms,... The problem is I don't have a "Burp" sub,
The truck res. is at 41hz, this box is tuned to 31hz,
I here people say tune 10 lower so that is what I did..
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
