Computer upgrade time
Final build pics , side fan isn't hooked up at the moment though.
Cpu temp is really good with only one fan installed. I have seen it as low as 24c idling . Pretty much stays at ambient room temp at idle . I have not run any serious stress tests yet to see where it goes under 100% load . Core temps are in the 35-40c range at idle. I have it slightly overclocked running at 3.2Ghz + turbo enabled so 3.36Ghz. Ram running at 1600mhz.
Run it on 3DMark06 to see what it has , stock 2.67Ghz + turbo enabled. Ram not even set right , just running at default 1067mhz it did 17,903.
Overclocked to 3.2+turbo / ram set at 1600 it did 21,338.
Pretty happy with it , runs really quiet .. almost silent. Surprised me with all the case fans it has.
2000 Trans Am ws6 - 6spd / M9 / cam / full bolt-ons / semi full suspension / tune
1998 Integra - daily beater, [2] AB XFL-1244's / 4ft³@35Hz, 61in² / Saz-3500dv1 @.85Ω
thats a good 3d mark score. ill bet you can bump that processor up even more than 3.2 also.
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Did a little foolin around with some settings and then run it on 3DMark06 again .
From the 21,338 score ..
I set Vista at performance setting vs. energy savings & went and set the graphics card to performance rather than quality (visuals still look good at this setting imo).
Results where a little better at 21,364 .
I've read disabling HT will boost the score so I went into the bios and turned it off. Everything exactly the same as before otherwise , the results where 21,927.
Real nice....
I would try to squeeze more juice out of that i7 920...
I would have gone with 30" of desktop real estate...lol
did you mention a sound card? Im hoping you're getting one soon. All that sweetness and integrated audio FTL
Over-all killer system, though.....let's see some numbers from Crisis (DX-10 mode :diablo: )
The integrated audio is not that bad. Has all the necessities and can do dolby, optical, etc... The new intel integrated audio on that board does 192 kHz/32-bit over 8 channels... :)
how much did all this run you?
Cost a little over 2 grand for everything , I am thinking of putting 6GB more ram in it for a total of 12GB.
Forgot to mention I went with a Pioneer BDR-203 Blue-ray burner/player , have not tried burning anything but it plays Blue-rays so all is good there. Looks awesome with everything hooked up HDMI.
The processor is D0 stepping , batch # 3910A314 / S-step: SLBEJ.
I went into the bios and upped the qpi to 180 for 3.6Ghz + turbo (3.78Ghz) , VCore voltage I upped .07500 but it booted at default 1.2100 . Basicly a 1Ghz increase , run it on Prime95 on 8 threads stressing it 99.x % for a while and it got to a max of 74c on one of the CPU core temps but most of the time it was about 71c on all 4 cores . CPU temp rose to 58c at max and never increased. Ambeint room temp was 26c.
Also run it on MemTest for an hour , run 8 instances of 562 each and had zero errors.
  • Who's Online   0 Members, 0 Anonymous, 1704 Guests (See full list)
