ok guys, im trying to figure this out. never have had a problem with this in my other installs but this is the first high amp ive had in my truck. i have all my wires ran on the left side on the truck in a tunnel that runs from the front of truck to the rear. which includes the 1/0 wire, 3RCAs, remote wire, bass knob wire, and one speaker wire.
now i checked the output on the amp, and on the front stage it puts out a wining noise from the rear stage as well. which means that the front RCA (memphis) would be bad, and the rear stage RCA (just got it today) would be bad. so i dont think its the RCA cables.
i also have a metal bracket he runs under the amp. i have the amp sitting under my seat with the amp on top of this metal bracket. now i dont have it bare metal to metal. i put some carpet over the metal bracket then put the amp down. should i do something different than the carpet like maybe MDF?
my grounds are good, power wire is good, no loose wires, no bare wires, no pos wire touching neg wire.
so im kinda clueless right now guys, any suggestions or advice would be great
thanks mike
Edited by FiBTLforlife
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
bad ground.. bad rca??
both RCA's being bad??? i just got done using the memphis RCA not long ago so thats why i kinda got it ruled out. but not completely lol
1 3500d AQ amp
I put a screw through one of my speaker wires once. I would just fallow every wire to make sure nothing happened. Did you recently do anything to car, ei. remove panels, something could have happened there.
could also be ground on radio or if u have an eq that doesit too or bad amp
Kenwood Excelon DDX812 6.95" double din
4 lvl 4 xl 15"
4 RF 1500
2 RF 600.4
2 15-MC5 - Memphis 5.25" 2 Way MClass Coaxial Speakers
2 15-MC92 - Memphis 6 x 9" 2 Way MClass Coaxial Speakers
2 mc memphis tweeters
memphis 16-EQP4 Signal Processors
4 2400 Kinetik
1 1800 Kinetik
iraggi 300
http://www.stevemeadedesigns.com/board/ind...showtopic=42009
ok guys, i ran the RCA's opposite of the power wires, re grounded the amp and even sanded down the metal. checked for shorts in wires, no shorts. no speaker wire touching metal. i even took the RCA that runs to my AQ amp and disconnected it from the HU and ran it as the front stage RCA (stinger). it still does it.
so now im like clueless. amp is bran new never been hooked up bf.
1 3500d AQ amp
I have an idea, and I think it would work, but I'm not 100% sure. Heck, I don't even know if it is safe. Granted, this is just trying to find where the problem is, not necessarily fixing the problem.
Turn the system on, then go to the amplifiers and one by one, pull RCAs. If the noise goes away, you know it is in the RCAs forward. If it remains, it's in the amplifiers backward. From there, you can go about swapping items to see if that changes anything.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
  • Who's Online   0 Members, 0 Anonymous, 2304 Guests (See full list)
