Who wants to help me on box specs for 4 18" BTL's?
newls1
well if you cant weld... then make sure the allthread barely touches and just fiberglass the joints
just make sure you fiberglass everything, and do little resin 45s, maybe and inch or two
it would really help if you can round over all the wood involved in the port too
you never mentioned sub placement, are they ok where they are at? if so im gonna run my numbers and give you a final volume and tuning
it is a big port, basically each sub gets 1 port section if you want to think of it that way, and each is 100sqin... so 100sqin/7cuft = 14.2sqin/cuft
it should be very loud and sexi with a plexi window on the back side, im assuming, facing the passangers.... get it etched or throw a sticker on the inside, a few LEDs behind the plexi and youve got one desirable looking box/setup
everything looks perfect, so if you want....RUN WITH IT MAN!
I love my staffie :good:
So anti FACEBOOK it isn't even funny
ok sooooo
using allthread
29.77cuft
31.43hz
using all 2x4s (which im going to suggest since u cant weld and it takes up more volume/might be stronger and easier)
28.66cuft
32.04hz
so i think im going to have to redo the sketchup to use 2x4 bracing instead... it will simplfy everything for ya... and you can glue and screw easily vs cutting metal, nuts and washers and extra fiberglassin
when do you need a cut sheet by?
edit* and if you use 2x4 bracing you can use 1 less port divider which gives you more port surface area and less friction, both will be a plus
no rush what so ever. I cant buy the BTL's until the next month or 2. In other words I have plenty of time sir. Thank you again, and yes, the 2x4 bracing will be MUCH better for me.
whats his new specs with all that 2x4 as its not gonna be close to what it was with the all thread.
I just for the first time went out and measured what 60" is actually going to consume, and HOLY CRAP! That is going to be fun as hell, I cant wait. I guess my tahoe will only be a 2 seat truck now. I dont give a damn, BASS HAS MORE PRIORITY then passengers IMO anyways. I'll have 7" behind the 2 front seats and thats it LOL! Enough room to slide in my amps, and i'll put the batts in the rear on a custom made "shelf" so it wont interfere with the 400SQin port LMFAO! Decaf.....If I had a dollar to my name I would be giving it to you for all your hard work brotha, I'll Paypal you later on once I can land my EMT job. Any chance when you have some spare time, you can hook me up with a cut sheet?
Never got my tahoe metered with the 2 18" BL's on ~1200rms each, but with this new BTL setup, and 8000RMS what do you think I might be able to get out of this.......145dB, 147dB??? But either way, I hope there will be a nice difference.
1.59cuft - 2x4 disp
~.41cuft - resin+mat+small 45s
_____________
2cuft + 1.04cuft sub disp
so
28.73cuft
31.79hz
im assuming some rounding of the port(s) will occur which will raise the tuning right up to 32hz
with the box only 24.75 high it has to be deep...
youre welcome, consider it ur new mod housewarming gift :friends::clapping:http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif
1.59cuft - 2x4 disp
_____________
so
28.73cuft
31.79hz
Your a good guy..... :friends:
you will be well over 150
ill go far enough to guess 154 ish...
you should look into adding a 4 x 4 right where the two baffle 2x4s intersect going from the top of the box to the roof to handle ur massive roof flex u will have
i wish i didnt have to wait so long
  • Who's Online   0 Members, 0 Anonymous, 1099 Guests (See full list)
