the amps gains were half way I never touched them since I bought them because they are tested an set on a scope before sold
When they were tested and scoped, were they connected to your headunit? If not, they could still not be set correctly. But first, you need to scope your headunit so you know when the headunit clips, then you can scope the amps.
97 Maxima SE
Bunch of shit going in, check out the build
That does make sense thanks man I guess I need to quite being lazy and make sure everything is set right this time
Under construction
soon to be:
2 DD Z9518's
8 lunar L1500's (500rms each)
Secondskin Dampner pro
250a Mechman rhino alt
4 runs of 2/0 (installed)
4 batteries (installed)
6-5 1/4's, 2-6 1/2's, 2-4in all ma audio (installed)
Here's a few pics from today I started reseining some 45's but I only did one it was cold today and that thing been dring for like 2 hours and just starting to get right now so nomore tell hopefully tomorrow if the weateher is hot like it been
Posted Image
then I started taking out all the amps and amp rack so I can take out the old box for the 15's
Posted Image
Posted Image
Posted Image
Posted Image
nice lil bird nest of wires i got here
Posted Image
Posted Image
heres all eight of my lil men waiting on the side line once again LOL
Posted Image
hopefully if the weather is right the next couple of days I will get all the 45's done and glass the inside up before I start installing the baffels. which gives me a lil time to decide how much port area I wanna run and what frequency i want to tune it at. Ohh I forgot the box is right at 12.8^3 before port and sub displacement. So if anyone would like to give me any ideas about the port I'll take it into consideration.
Under construction
soon to be:
2 DD Z9518's
I would tune higher than 32hz...DDs don't need a low tuning to drop low....also nice chair lol.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
thanks man I was thinking about tunning it to like 35ish but im not certaint yet. So how much port area would you run for 18's in a box 12.8^3 before displacement?
:edit: I knew someone would say something about my chair LOL!!
Under construction
soon to be:
2 DD Z9518's
must say, I would have NEVER thought of the bracing idea with the alumin bars.
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
Here's the last look at the Z9515's before I went drop them off to get sent back to DD, there commung back as 18's. I was going to do the blow thru with the 3 15's but I realized that 2 18's has almost the same cone area as 3 15's. So I will start building a new wall next week for the 2 18's. DD calls for 6.5^3 per woofer with 107 square inches of port. I will be running around 10^3 for the par can any one tell me how much port area I will need? I plan on tunning it to around 32ish. Any help will be greatly appreciated im tring to have this thing ready for siknik so if anyone is going you'll let me know I want to met some of the members here and hear what you'll working with as well ,and of course give some demos LOL!!!
just keep the same ratio
16.46sqin/cuft
so if 10cuft*16.46sqin = 164.6sqin
is that 12.8cuft external or internal dimensions?
hopefully internal because ur box volume is gonna be kinda small
16.46sqin/cuft
yeah it's 12.8 internal! I'm glad I decided to go with the 12.8 instead of 10 like I had planned! The reason I wanted to drop the size down and go to 10^3 was because of my previous box, but I went ahead and started building it to 12.8, but now that I did more research and ask more questions I found out that my previous box for the 15's had a few flaws in it and if I would of based my new box off of the results from the last one and went with the 10^3 I would b starting all over.
Under construction
soon to be:
2 DD Z9518's
How can they set them with a scope before they're sold? they dont know exactly what your input voltage is, and final impedance seen at the amp.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
Nice! Would be kick ass to see a video..
