i wouldnt wanna drop below 12 volts in any setup. dropping to a lower impedance increases current draw, so you usually gotta be more careful when doing that
anything below 1ohm just becomes a warranty issue I believe
They'll do that all day long. I'm currently running my saz-3500d @ 0.4dcr daily no sweat. I ran my saz-1500s daily @ 0.35dcr for months with no issues. Just feed it the juice it needs and you'll be plenty happy.
nice.
just remember it takes power to make power
lowering the ohm load makes more power therefor you need moar power to feed the extra power being made
common sense :)
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
I'll also add that my brother has ran three d2 Btl 18s wired all parallel to a 0.33ohm nominal load (that's 0.25dcr) on a single saz-3000d and played music on it daily just fine. He only did it to get into a lower power class in local comps. That single saz-3000d @ 0.33 powered those three 18s good enough to still do a 150db & change on a burp even after demoing music all day long.
  • Who's Online   0 Members, 0 Anonymous, 1611 Guests (See full list)
