Gary's (aka BanginAltima) 150db Plus Trunk Build...**Hopefully**
Here is the equipment I plan on trying to hit my 150 with.
Two Sundown Z15's Dual 2 ohm coils.
Two Sundown Saz-2000 amps.
Two 6 inch Precision Sound ports.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
I also have two XS Power D3100, not pictured.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
150 shouldn't be a problem. Bassracing a 149.9 and not breaking the subs might be your issue. Here's the other thing that I've ran into with identical equiptment. You know that I have 2 2000's and 2 D3100's and with the car running in idle and volume all the way up sometimes an amp will go into protect. With the volume all the way up the car is still way over a 149.9, but it is an issue especially after 2 ties in bassrace when you have to shut the car off. With even less voltage the amps may protect on you. I'm working on fixing that problem right now so I'll let you know what I come up with if you want. I'm sure a 250 amp alt will help with the car on but car off is a different story.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I hear you, taking it one step at a time.
I do box designs.
yea should be good but curious whats the tunning gonna be
Planned box tuning is 34 Hz.
I do box designs.
should be interesting. im tuned in :)
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
facing upwards with ports facing forwards iirc
are you going subs facing front or rear?
Subs forward and side ported.
Posted Image
Sidenote: I do box renderings and cut sheets....PM me.
I do box designs.
Posted Image
I've never seen that before with those types of ports.
Looks interesting.
Subscribed.
4 18's, low power and lots of gay fur.
Team gg
Team DOA
My Videos :)
