best way to level a tahoe out
To tighten the torsion bars and raise the front end does it have the truck have to be off the ground im thinking about doing thi to my Silverado
yes, atleast the front. also i would reccomend an alignment afterwards or you can have some odd tire wear.
center console: lvl 4 12 1.75 cu ft tuned 37htz
alpine cda-9886
dc audio 120.4
infinity kappa 6.5" components
I am about to order the Ford torsion keys for it so that I dont have to crank them all the way up there is a good write up on FSC about this
If you are only wanting to level it, and are talking 1" lower rear, the best way would be to get new rear shackles. this wont affect the spring in your front torsions, put you lower and not higher, and they can be found pretty cheap. for 1" rear drop, you want 2" longer shackles (half the spring....) I made my own shackles so you could probably find some metal fabrication place close to you to have a set made up ^_^
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
ok so i have an 03 tahoe that i want to level out. IDC if i raise the front or drop the read.I was wondering what the easiest and cheapest way is to do it. I know the torison bars are alot of work to put on and they run around 130. I heard the only way to drop the rear end is new springs but how much would that run me. Any other ways?
You can usually take it to a muffler shop to get the rear coils heated, little by little you'll see the rear dropping...thats probably the cheapest way to even out a tahoe
Team Bass-Hz
ya thats also ghetto and unsafe
tahoes dont use shackles like chevy trucks. That was the first thing i looked in to
heres a good write up, with pics. http://www.fullsizechevy.com/forums/genera...acing-tech.html
alpine cda-9886
dc audio 120.4
glad someone else said this, being new didn't want to be the one....
So, they are coils on the back? I will stay tuned to find out your fix. ^_^
7" BDS HC lift kit
just so somebody doesn't make a mistake if you have a s10 do not get tbar keys you will run through front end parts every month you can't get the right angles to make it work
and getting keys for 1" is dumb I raised the blazer 2" with sagging bars
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
  • Who's Online   0 Members, 0 Anonymous, 1677 Guests (See full list)
