8000watts Posted August 4, 2009 Report Posted August 4, 2009 so i changed my oil today and my ass put 10w 40 in my car :01nocomment8so: ... about an hour after the oil change, i decide to check what kind i shoulda put...5w 30... what if i go change my oil to 5w 30? could i use the same oil filter from todays change??? Quote
hdrox88 Posted August 4, 2009 Report Posted August 4, 2009 I would change it cause I have OCD when it comes to stuff like that but you should be fine. Quote
8000watts Posted August 4, 2009 Author Report Posted August 4, 2009 I would change it cause I have OCD when it comes to stuff like that but you should be fine. lol k thanks... Quote
sactownstang Posted August 22, 2009 Report Posted August 22, 2009 it's a new filter, shit i would keep it on their.... Quote
Rogers Posted August 22, 2009 Report Posted August 22, 2009 the 10w40 is fine.. it wont hurt anything... Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
rusty959 Posted August 22, 2009 Report Posted August 22, 2009 Id also say just leave the oil in. But definitely there is no need to change the filter even if you do waste the money to change the oil again. the oil will mix as it goes through the filter, the little bit left in there won't make any difference in the other oil etc Quote 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959
str86diesel Posted August 25, 2009 Report Posted August 25, 2009 As said above, just leave the 10-40 in the car, it won't hurt anything. There is very little difference between 5w and 10w Quote 2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
newls1 Posted August 25, 2009 Report Posted August 25, 2009 I would change it cause I have OCD when it comes to stuff like that but you should be fine. Im the same as you! When the slightest thing is wrong with my tahoe, I try to repair it 150% Example: Last month while I was changing its oil, and cleaning under the hood, I looked at the area where the heads meet the intake manifold, and it was HORRIBLY dirty. Long story short, and 5 hours later (At least) I took off the intire top end of the motor, replaced intake gaskets, and cleaned everything off, and soaked the manifold in parts cleaner to get all the oil build up out from the inside, and it was FILTHY! Quote I love my staffie So anti FACEBOOK it isn't even funny
Guest Posted August 25, 2009 Report Posted August 25, 2009 Im the same as you! When the slightest thing is wrong with my tahoe, I try to repair it 150% Example: Last month while I was changing its oil, and cleaning under the hood, I looked at the area where the heads meet the intake manifold, and it was HORRIBLY dirty. Long story short, and 5 hours later (At least) I took off the intire top end of the motor, replaced intake gaskets, and cleaned everything off, and soaked the manifold in parts cleaner to get all the oil build up out from the inside, and it was FILTHY! can you look at my engine? Quote
