Rogers 93' chevy lumina build!
a fancy home made terminal...(bolts)
Posted Image
Quick question is that a metal or plastic plate?
Pushing it to the limits. Want more power.
that would be plastic my friend... i actually cut it out off a lid from a storage tote, prepped and painted it... i think it looks pretty good myself... better than just bolts sticking through
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
i thought the same thing but knew he wouldnt do a noob mistake like that haha
looks HELLA good bro...keep up the good work :D
NoFearX18 said:
trainman0978 said:
looks nice and thanks for reminding me about the body ground, mine broke off, time to fix it
03 Ram 1500 3.7 v6 quad cab
H/U: Pioneer 4200UB
Subs: 4 DC LVL 4 15s D1
Sub Amp: 2 Crescendo 3kwp strapped
Highs Amp: Crossfire xp240.2
Highs: Crossfire 2 rs69, 2 rs52
Alt: DC POWER ALT 270XP
Batts: 5 sprinter data safe
Big 3 0ga
New Truck 03 Ram Build Log 6 DC Audio lvl2 15's
My Wrecked 99 Dodge Ram Sport Build Log
02 Ranger X Cab Build
02 Ranger Build 2
http://www.dcsoundlab.com/
My linkhttp://www.crescendoaudio.com
http://www.dcpowerinc.com/
http://www.crossfirecaraudio.com/
Youtube Vids
well i worked on it some more today... i cut some of the unnecessary metal out of the trunk opening to make it look better and i worked more on the false floor... i also have 2 regular batteries that im in the process of hooking up behind the driver seat temporarly so you guys can have some vids...
3 Kinetik Hc2000's
Dual 200amp alts.
hehehe i used the meteor shower as an excuse to stay out and work on the build... well i think im pretty well done with the amp rack for now... when i can afford the rest of my equipment ill rebuild the rack... but i like the way it looks... it looks clean but custom made.. if you know what i mean...
anyways.... its hard to remember to take pics while your working... it just kinda slips your mind.. but i was able to snap a few
humm i dont have a back seat...
Posted Image
who the hell is going to need seatbelts?
Posted Image
i ended up cutting the crossmember board in half length ways and then i bolted it on each side and made a couple 1/8th inch thick braces for the middle... but i forgot to take pics...damn i also drilled holes through the rack to run my wires through...
anyways once i had it built i pulled out all of the upper and lower trim (except for the back dash) and cleaned everything real good and began carpeting...
Posted Image
and this is pretty much where im at with it at the moment... i still have to screw down the amp plate and i have to fix my damn fuse block... i accidently broke it... kinda bummed... but a little epoxy and nobody will ever be able to tell... i ended up running 2 runs of 14guage wire as the 8 guage wasnt long enough...but ill swap it out when i get somemore wire im not sure if 2 runs of 14will be able to handle that much power...
Posted Image
Posted Image
Posted Image
Posted Image
3 Kinetik Hc2000's
Dual 200amp alts.
got the first vid here!
Posted Image
DAMN, was just going to message you to see how it was going. where the hell was I- ok. will comment in a minute- want to catch up on thread :clapping:
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
yeah its got a big trunk... but wish it was bigger... i would have done 8 of them...lol
Dont give me any idea's......longbed dually, snugtop in the garage, might have to do it......nah, pretty happy with how yours turned out. will stay with 4
Funny chit mane, thought the same, then was like "No, not roger" lol. sweet build bro. So, you happy with the AQ? noticed your bass knob only turned halfway up - scary first time cranking it up huh! Looks SICK!!!!!
7" BDS HC lift kit
