RE Audio RE Components
Thewes
just use one.
they do over 200 x 2 @ 2 ohms, so each door would get at LEAST 100w, prally more like 125 per door, which is plenty.
Aren't those components 4 ohms? In that case use both amps. 1 for each pair/set.
My Official Feedback Thread
PSN - tech2332
Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
they are just a bit on the bright side iirc
the crossover that comes with them says it has a Tweeter Attenuation Control... or a switch or something to lower or raise the tweeter level in the crossover
These are the RE RE components, not the XXXs. My crossovers have no switch :(
yes they are, but he has 2 sets. if he uses a single 125.2, and he wires the drivers side (front and rear door) in parallel to the left channel, thatll make 2 ohm on the amp. same with the passenger side, wired to the right channel.
i think they do, ill double check next time you come over.
Could always also go active :)
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
  • Who's Online   1 Member, 0 Anonymous, 587 Guests (See full list)
