I just installed 2 L5 15s dual 2. I use to have 2 CVR 12s and the L5s are just as loud if not softer. Both were in put in enclosures made be me.
Here are my box specs for the L5s
11.5 cu ft.
35 hz
and (this is what might have gone wrong) the port dimensions are 11x11x14. I think that comes out to 141 sq inches of port area, is this close or how off am i?
Is the port too big or am i just no allowing enough time for the subs to be worn in? If you guys need anymore information about the subs just let me know. Thanks in advance. :hi:
Edited by GoldElks
11.5 cu ft.
35 hz
and (this is wha might have gone wrong) the port dimensions are 11x11x14. I think that comes out to 141 sq inches of port area, is this close or how off am i?
What kind of amp are you running? Box sounds a little big for two l5's
98 Jeep Wrangler
33x13.50 super swamper LTB's
Memphis M3 15"
Memphis MCD1000
Optima yellowtop D34/78
Bass Race 129.9
(LBZ Duramax in the future)
I am running a Crunch 1500.1 at 2ohms and Kicker says the "VenterSPL/DeepBass (MaximumEnclosureVolume" for one L5 is 6 cu ft so i figured a little bit smaller wouldnt hurt.
Edited by GoldElks
you cant really expect 2 different subs to sound the same
I am not expecting to subs to sound the same?... I am expecting the new to be better than the old, if i did not expect that I wouldnt of upgraded.
If 11=H and 11= witdh then you have 121sq inch of port area, not 141sq inch.
You need a minimum of 138sq inch or max 184sqinch.
So you're about 40sq inches short to be around optimum port area.
I have 2 L7s and I felt the same way, thought they would've sounded better, it just took a while to break them in, now after a couple of weeks they wang hard.
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
they need to be in 3-6 cubes...which u did...but if it were me, i would make a box that was about 3.5-4 cubes per sub...should give it more punch.
or u can give them more power in that box...but i dont really like overpowering subs...
i likes me some audio stuff...
  • Who's Online   1 Member, 0 Anonymous, 884 Guests (See full list)
