16.20 volts at idle
Alternator has a built in regulator on that type of vehicle. I wouldnt be leaving it on to long with that kindof voltage either. 2001 GM vehicle's computers are not made for 16volts. Have any check engine lights on yet. Im suspecting you will be getting one for over voltage code. If you DMM is not crapy. Whens the last time you replaced the battery in the DMM.
They may not be built for it, but they are designed to tolerate up to 24 volts for a few seconds.
OTOH, is the check vehicle light coming on?
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
I wouldn't drive it if that is the case man, you are literally smoking your batteries if you do that for long periods of time. Some battery chargers that trickle will dip up to 15.9-16.2 on there for 3 hours on acid batteries from my exp. For car audio batteries, or any style of AGM batteries in general... 15.3 is pushing it. I'd get it checked out. See if the vreg is adjustable. if not check for shorted wires on the harness going to the alternator. If not.... You can but replacement voltage regulators for around 10-15 bucks depending on your model. springhillautoelectric should have it in stock for you.
i doubt it is adjustable its a factory alt. is this the reason my amp is cutting in and out also? i also disconnected the sub amp and the voltage was the same.
Yeah, some amplifiers start acting up at higher voltages. Your car is fine with 16 volts. Most modern cars can handle quite a bit more. Mine throws codes at around 16.5. I'm more concerned about your batteries though. I'd look into replacing the voltage regulator since the alternator may still be charging fine. In the mean time you can go to autozone and have them do a test on it for you, just to make sure it's doing rated amperage and such before doing anything. Either way it's not super costly and the voltage regulator is most likely is the culprit, I'd post up something in mechman or dc's section to confirm before throwing money into a puddle though. They are the true guru's.
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
i pmd dc audio so im waiting to hear from him. i was going to take the alt to advanced auto tomorrow and see what its doing. i wanted to get a high amp alt anyway so this would me a good time if any.
lol i hope you sent a msg to DC Power not DC Audio :) 2 diff companys bro, but either way good luck with the problem, let us know how it goes, and what is the problem :)
Team_DC-Derrick's Youtube
Team DC Audio
yeah i meant dc power
ok so ive called the parts stores and none of them sell a voltage regulator by itself so now it looks like im stuck having to buy a reamanufactured one to get me by cause i need my truck. that is unless someone in missouri has one a high output alt for sale. i live in st louis near south county. if someone does please get ahold of me.
I also would wonder about that DMM...
x2 i have a hard time believing a 12v battery would rest at 14.6
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
Thats the frist thing I thought....
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
  • Who's Online   0 Members, 0 Anonymous, 853 Guests (See full list)
