How big is yours? (Monitor Size)
here's mine Posted Image
LCD feature Specification
Display size 17-inch (43.2 cm) diagonal and viewable image
Display type Thin-Film Transistor LCD active matrix
BriteView technology
Input terminal VGA 15-pin D-type connector
DVI-D connector (cable not included)
Speakers 2 integrated speakers
1 watt each, 2 watts total
Scanning frequency Horizontal scan range 24-83 KHz
Vertical scan range 55-76 Hz
Native resolution (H x V) 1440 x 900
Contrast ratio up to 600:1
Response time 8 ms (on-off)
Pixel pitch 0.255 mm
HDCP (High-bandwidth Digital Content Protection) Support for HDCP enables the monitor to display HDTV resolution if connected by the DVI connector. A monitor without HDCP support, or connected by analog VGA, causes the displayed video to be downgraded in quality to a DVD-like resolution that is less than HDTV.
HDCP is also a content protection system. The goal of HDCP is to prevent transmission of non-encrypted high definition content.
Power source - AC/DC adapter Input rating: 100 to 240V~
Power consumption: <37 W in operating mode, <2 W in sleep mode
Operating environment Temperature: 41 degrees F to 95 degrees F (5 degrees C to 35 degrees C )
Humidity: 15% RH through 90% RH (non-condensing)
Storage environment Temperature: -4 degrees F to 140 degrees F (-20 degrees C to 60 degrees C)
Humidity: 5% RH through 90% RH (non-condensing)
Dimensions H x W x D, including base:
14.3 x 16.2 x 7.2 inches (36.4 x 41.4 x 18.4 cm)
Weight Unpacked: 5.9 lbs (2.7 Kg)
EMI standard FCC Class B
Mounting Standard VESA 4-hole 100 mm x 100 mm
EPA Energy Star As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency.
42" Samsung HDTV when watching movies/playing games/goofing off.
The built in 15" LCD when doing school work.
When at my brother's house, I use his 52" HDTV for movies and goofing off :D
Oh yeah, my other laptop is 17" (I think...)
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
2008 Subaru Forester XT
My parents:
22" eMachines and 46" LCD tv.
Mine:
15" compaq laptop and 15" Sony.
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
I have a 20" LCD for my computer, but I could hook the computer to my 60" Plasma Sony.
¿ǝɯɐƃ ǝɥʇ
i can hook up to my 50 inch Samsung HDTV....but im running on my HP laptop 17" widescreen HD
and i have a 17 inch LCD on my other computer
dude, I have the same 50"......I can plug right into it?...sweet!
I just have the P O S dell monitor. Think its a 17? maybe smaller. would be sick on the 50"
Edited by 98crewcab
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
most tvs now a days have VGA and HDMI ports on them, which allows you to hook a pc up
both my tv and my computer monitor are Samsung 19" LCD's. they're plenty for me
Edited by J00bles
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
  • Who's Online   0 Members, 0 Anonymous, 1295 Guests (See full list)
