So Iv been working on my install for a while & I finally added 2 spare batteries in my truck got it all wired up & when the subs hit my stinger voltage meter just reads "lo" & my lights still dim like crazy. This is my first time adding batteries to a setup. Any Help?
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
I dont have a clue as to whats wrong with your volt meter but I wanted to reply to your post cause I noticed no one else has lol. I would maybe ask the same question in the battery/alt section!
Kenwood Excelon KDX-693 Head Unit
Kinetik HC600
Powerbass 6.75's in front doors
Powerbass 6.75's in rear deck
Powerbass 1000.1D
Powerbass 400.4
2 SA-12 inch Sundown Audio Subs
0 gauge Power Wire and Big 3
Custom Amp Rack
Code Alarm with remote start
Stinger Digital Volt Meter
My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/
My youtube channel http://www.youtube.com/user/kanesdisciple
Are they resting at the right voltage? If so I would say there is either a wiring issue or something up with your alt. Are you on a stock alt? What kind of wire did you use from front batt to back?
Too many projects, too little time...
Yeah the batteries sit at 12.4 & 12.7 when I got them. The alt is stock for a while until I get a job agian, & the wire is knukoncepts KLMX 1/0. Heres a picture, but a few things have changed I ditched the ground block & bolted the grounds to the bed, on the bottom side of the bed I added a ground strap fromthe same bolt to the frame, so my batteries are indirectly grounded to the frame.
Big 3 isnt done in this pic but you can see that I did it.
Current System:
Pioneer 6900 HU
Bass:
I would recheck your grounds just to check, then...idunno. Maybe your front batt is bad? Did you have a big voltage drop just off the front batt?
moving to the battery section...
not sure what the problem is...but i would not ground to the bed...i would go thru the bed and ground to the frame of the truck
i likes me some audio stuff...
Yeah, it was dropping into the 8's.
Sorry, thanks for moving. I didnt really ground it to the bed, more like I used a bolt to transfer the ground through the bed, on the backside of the bolt I have a ground strap. I should have taken a pic but didnt. Only one battery is hooked up right now, & its helping bc my voltage doesnt go below 10 now but stinger says 1 of these can support 3400 watts. I only have 4400 watts rms @ 14.4 volts. so I probably have 3000 watts maybe. Idk.
Current System:
Pioneer 6900 HU
Bass:
i had th klmx 0 gauge for a while, it kind of sucked. moved to the kollosus fleks, way better. it helped with my voltage drops and all of that.
Alpine 9886
Polk Audio 6.5 Component db series
Elemental Designs nine.4
JL Audio 1000/1
DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz
Clarion EQS746
Stinger Voltage Meter
Optima Yellow Top (Front)
XS Power 1200 (Rear)
All KnuKonceptz Wiring
I got it bc I needed a long run of wire 7 & the flex was twice the price. I used flex to connect the batteries & also ran it into the cab, it is awesome wire without a doubt.
Current System:
Pioneer 6900 HU
Bass:
  • Who's Online   0 Members, 0 Anonymous, 3609 Guests (See full list)
