nice. i would like to see some head to head tests on 13.8, 14.4, 16, and 18 volts.
i'm sure you'll win on all though with cleaner watts.
Haha, the AQ3500 looks tiny comparred to the saz3500. Who says size doesn't matter?
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Power Test Completed.
I know someone will ask these questions SO READ THIS FIRST :
1) AQ-3500D Tested First - Battery Bank had a charge for several hours from our bench power supplies
2) SAZ-3500D Tested Second - Only a few minutes behind the AQ-3500D Test
3) THIS IS WHY the 3500D had much more voltage drop, I had the entire surface charge gone from the batteries
4) Both amps set wide open to be apples to apples.
AQ-3500D POWER TEST:
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2679.MOV
AQ-3500D VOLTAGE TEST:
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2681.MOV
POWER : 2400 Watts
AMP VOLTAGE (measured) : 71 V
AMP CURRENT (calculated) : 33.8 A
ACTUAL IMPEDANCE (calculated) : 2.1 ohms
SUPPLY VOLTAGE : 14.22 V
SAZ-3500D POWER TEST:
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2682.MOV
SAZ-3500D VOLTAGE TEST:
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2684.MOV
POWER : 3020 Watts
AMP VOLTAGE (measured) : 77.2 V
AMP CURRENT (calculated) : 39.11 A
ACTUAL IMPEDANCE (calculated) : 1.97 ohms
SUPPLY VOLTAGE : 11.99 V
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Boo, damn biased opinion coming from you Jake. J/k, I'm not surprised at all. Just to do so you should put up some test results once the batts charge back up and show the people what the amp will make in a FAIR comparrison instead of giving yourself a handicap.
1 XS Power D3100
Audio Control LC6i
Stock Deck
NICE!!! I want a SAZ-3500!
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
