Jared420 Posted August 28, 2009 Report Posted August 28, 2009 Ok I know its a dumb question but i have to ask, Why is it that my system is very noticably louder and hits lower/cleaner with my windows completely down than with them closed. Its a very noticable difference and im sure this is the case with most people more often than not. Just wondering outta my own curiousity what the reason for this is? 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
troy Posted August 28, 2009 Report Posted August 28, 2009 bass is just moving air. if your windows are down the air moves and isnt trapped in side the cabin retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
1030tooled Posted August 28, 2009 Report Posted August 28, 2009 This is why people port/vent the box. AIR transfer 93' Ford Aerostar Alpine head unit 4-5.25 MB Quarts 20-10" pyramids super Pro 1 Lanzar amp
troy Posted August 28, 2009 Report Posted August 28, 2009 This is why people port/vent the box.AIR transfer exactly retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Nightshade Posted August 28, 2009 Report Posted August 28, 2009 Part of it is also that quite a few trucks have a standing wave. The length of the wave can't crest inside the vehicle because it's probably tuned lower then your vehicle will allow for so when you open the windows it allows the wave to make it's peak and is noticeably louder to the ear. The same thing happens in Brandon's truck from Sundown. It used to be Assman's so you may know the truck. Anyway the box is tuned way too low for the wave to peak in the truck and only does like a 150 sealed, but if you open the door it lets the wave make it's peak and will do a 155. Like I said the problem is that the box is peaking too low and doesn't hit your ears with full potential. That's why blowthroughs usually work quite a bit better since you can tune them lower because of the further distance from the listening area. The same is true for an suv, hatchback, and trunk car. This holds especially true with walled vehicles. You will find that almost every daily driver with a wall will be louder with the windows open then closed since they're tuned too low for the vehicle to play efficiently. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Jared420 Posted August 28, 2009 Author Report Posted August 28, 2009 Part of it is also that quite a few trucks have a standing wave. The length of the wave can't crest inside the vehicle because it's probably tuned lower then your vehicle will allow for so when you open the windows it allows the wave to make it's peak and is noticeably louder to the ear.The same thing happens in Brandon's truck from Sundown. It used to be Assman's so you may know the truck. Anyway the box is tuned way too low for the wave to peak in the truck and only does like a 150 sealed, but if you open the door it lets the wave make it's peak and will do a 155. Like I said the problem is that the box is peaking too low and doesn't hit your ears with full potential. That's why blowthroughs usually work quite a bit better since you can tune them lower because of the further distance from the listening area. The same is true for an suv, hatchback, and trunk car. This holds especially true with walled vehicles. You will find that almost every daily driver with a wall will be louder with the windows open then closed since they're tuned too low for the vehicle to play efficiently. Thats a damn good explanation! 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
1030tooled Posted August 28, 2009 Report Posted August 28, 2009 Nightshade Are you saying, car subs are loud...and create noise? 93' Ford Aerostar Alpine head unit 4-5.25 MB Quarts 20-10" pyramids super Pro 1 Lanzar amp
Nightshade Posted August 28, 2009 Report Posted August 28, 2009 NightshadeAre you saying, car subs are loud...and create noise? Sub go boom, make ears hurt, I like sub 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
tristan560 Posted August 28, 2009 Report Posted August 28, 2009 Sub go boom, make ears hurt, I like sub New sig! <u>99 Jimmy SLT 4WD</u> Systemless. <u>99 Grand Prix GTP</u> DC XL 12 on 1.5k tuned lowwwwww.
