Hi guys im looking for some suggestion on amps that are readily avalible tha do 1500wrms at 1 ohm
i was looking at the usamps XTD4000 1500wrms @1ohm but it only has 75amps of fused when my orion hcca2400D 1200wrms has 90amps of fuses
any sugestions of an alternative ?
Up Front: Alpine 9855r kenwood 6X9s :P
Boom 10 JBL GT4 10s series tuned tunnel 2 Orion HCCa 2400Ds Powerd By Squadron Energy
Peak: 148.8@38hz 40hz:147.8dB 33Hz:147.5dB 25hz:145.2dB 20hz: 141.7dB
sundown saz1500d
http://www.db-r.com/sell/store/
diablo audio technologies hellfire 1000.1 will easily do 1500 @ 1 ohm
http://diabloaudiotechnologies.com/hellfire.html
audioque 2200d. its rated a little higher rms but around the same price as the above
http://www.audioque.com/aq/order.htm
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
with those fuse numbers I don't think so, if my math is right? The orion at at 14.4 volts would be 1036 (14.4*90-20% assuming that the amp has a 80% efficiency rating), so the xtd4000 at 14.4 would be 864 (14.4*75-20%assuming that the amp has a 80% efficiency rating), and that assuming you dont have any volt drop...
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
that was i was thinking there are few ofther proper 1200wrms amps like the SPl dynamic 1200d and they have 120a rating which i think is a bit more realistic
in all honesty no amp company can touch the Zeff designed clarions that are on crutchfield right now
200 bucks for 1500rms albiet at 2ohms still a crazy deal
do you have the speakers already? what ohm config are they if you do? hell at 4ohms the clarion will do what the usamps will at 1 lmao
Edited by Sparkomatic
Hey man that's a good call I have 24 4ohms SVC subs so its either 6 medium amps 1@ohm 3 big amps @.5ohm or 12 small amps @2 ohms ant other configurations I'm not thinking off?
Edited by lozzyTGP
thats a good deal if they do what they say they will do..
there a lot of cash lol ! nice looking amp :D i think its gonna be a battle between the sundown and the diablo to take pride in my boot!
