nice work on the ports mayne!
what kind of glue did you use to glue the ports to the pvc?
Looks nice Derrick! You guys gonna have it finished this week or next?
It will be done and playing for Nspl finals next weekend.
Liquid Nails. Roughed the pvc up with some 80grit and a wire brush first. I also used a 1/2" roundover on the inside of the wood to give a little extra groove to get the glue down in there.
The ports are completely done & mounted and the box itself is assembled. I had pics but after an issue with my memory card they all got deleted. Won't be able to get back on this til Monday. Then all the sub holes will get cut, corner bracing will be added, and all thread bracing installed.
Today's work.
Got all the sub holes cut.
Posted Image
Posted Image
Shot of the ports from inside the box.
Posted Image
Posted Image
Time to flush & flare the ports from the outside.
Posted Image
After the flush bit.
Posted Image
I flare it in stages. First a 3/4" bit then two passes with the 1.5". Pictured here the center is flared 1.5" & the two outside ports are flared 3/4".
Posted Image
Posted Image
All three ports flared with the 1.5" bit.
Posted Image
Posted Image
Posted Image
Test fitting the subs.
Posted Image
Posted Image
The rest of the subs. As soon as I pick up a roll of speaker wire they'll all get installed.
Posted Image
The only thing left is the corner bracing and threaded rod. I started installing the threaded rod tonight but didn't get finished. All that will get done tomorrow.
  • Who's Online   0 Members, 0 Anonymous, 985 Guests (See full list)
