i dont understand quarterwave design at all.
can anyone help me? i wanna start making tlines and quarter waves but i have no understanding of them whatsoever.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
ok, i understand length/tuning and size now, but dont you need like acceleration chambers, slaughter chambers, this chamber that chamber and every chamber inbetween? and can the whole box be one long port the same width??
You can make it ultra-complicated if you want to; then your box will never get built. Just read the T-line post and trust the numbers.
I have built a lot of enclosures and sometimes I still get butterflies waiting to see if it will sound good. They always sound just like they were supposed to and yours will too if you take your time and do it right.
Just do it! If you get stuck on anything, just post your questions on the Forum and I'm sure someone will help you.
Good luck! :hairtrick:
Uh, maybe if you're building the box to some exacting spec based perfectly on the drivers TS parameters... if you just want a T-line, build a T-line, it'll almost always sound alright if you just make it a straight line at approximately the Sd of the sub, maybe a little less if you're running quite a bit of power.
Walk before you try to run... I built a horn the other day that was completely wrong, not made to spec and basically made up the dimensions on the fly and it still sounds farking sweet :) But I probably got really lucky, and it was a very very simple horn (single-folded tapped horn)
10.x volts fo' life!
I hate the term, but KISS- Keep it stupid simple- or whatever it is
Start off with a very easy design, hell even a PVC pipe and make some MDF adapters to mount the woofer inside it- Thats how I started, just some 5" and 6" mids and PVC, practice, learn, document
i just designed a tline tuned to 30hz for a 8" kicker comp just to see what it sounds like. is that a good tuning freq??
your supposed to use the drivers Fs
i know, what i saw showed me 30 which i KNOW is wrong...
  • Who's Online   1 Member, 0 Anonymous, 1137 Guests (See full list)
