Are you going to make a full trim panel for the rear. I think it would make it look real nice. But so far so go keep up the good work.
still trying to figure out what im gonna do there, i will definalty be making trim panels to go around the wall and seal it off the same as the front, but im thinking about doing a full fiberglass mold of the whole lot to cover all the wires etc...
I can't guess
heres a clue:
^^^ clicky pics for build logs ^^^
Mmmmm moar speakarz!!!! Trunk speakers are awesome!
1988 Honda City E
  • Big 3 in 1/0
  • Venom 6x9
  • Venom 6.5 Components
  • Response 4x100 midz and highs amp
  • Fusion NV 2500.1: STOLEN
  • 2 x 12 inch fusion nv subs
  • 10 inch 5 doller subs in my doors
PM me if you want help with electrical
Double post...
1988 Honda City E
  • Big 3 in 1/0
  • Venom 6x9
hey guys,
looks like my superlong title succeeded in getting me moar hits :P win!
well heres the start of my boot speaker pods :)
the one on the right has spacers to clear where the RCA cables run down from the amps...
and the baffles:
once i test fitted them i realised that the baffles were a bit big so i cut them down flush with the speakers
then glued/screwed the baffles to the base
both sides done:
the crossovers fit in behind the speakers once i took the rubber magnet boot off, im not sure weather to put them here or above the 4 channels on the back of the wall though:
thats all for now :)
Believe it or not i just went through all 5 pages!:o
Anyways, I like how you did the port on that diamond, looks pretty tight.. I did notice you turn that headunit 1 volume away from its clipping point..be careful :D Can't wait to see the clamshell? :woot:
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
That's bad ass, I'm running two of the 4 ohm coil GTO15s, I always thought of getting another two, but i didn't think they'd do that much damage! How much are you running per sub?
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
aha looks like all you guys needed to hit me up was a good superlong title :P wish i though of that before...
my monoblock is rated at 1500wrms at 1 ohm but after box rise and voltage drop im probably only giving them about 300w each?
todays work?
i found an old tshirt in dads rag collection and cut it up for wrapping the pods :P
and thats about it, tommorow imma try something different than the old fiberglassing method...
Keen to see the "different method" you have planed. I am always open to ideas. My pods are now build but need some work as they hit the dash as I close the door. there is like 7mm in it. :fail: I will get that fixed and update mine soon.
Wall looking good and gets the honeys hair a trickin just right. Which one is yours in the 3 chick vid?
Systems:
Fun Car:
Deck: Alpine CDA-9887
Front sounds: Alpine SPR-175A x2
Front power: RF T400.2 Benched at 265x2 rms @ 2ohm
Subs: RF T1 10 dual 4 Ohm x1
Sub power: RF R500.1
Box yet to be built.
All in a Mazda 323 Hatch in the cargo area only.
Daily hack:
Deck: Alpine CDA-9886
Front sounds: RF T152 5.25" coax x2
Front power: RF Power T400.2
Subs: Alpine SWR-1021d x4
Sub power: RF Power T20001
4.59cuft net 56" of port tuned to 32hz.
Work ute
Deck: Alpine iDA-X303
Speakers front: Stock
Speakers rear: None
Subs: Alpine type S SWS-1040
Amp: Alpine MRV-T320 x1 for woofer.
Box 1.42 cuft 39hz hidden under tray in blow thru design.
New ute to be much different.
cheers mate, im not sure if it will work yet but il post progess if it does or not...
in the 3 girl trick none of them are mine lol :P, my girl is the one in the daytime vids in the diamond, and my avatar... her hair is a bit long to do it very well in the windows :(
next weekend ive got my first comp coming up so now im in panic mode to get everything ready, my team will be entering 3 cars too which makes it even trickyer lol, il update as the week progresses :)
