Just got some DD 3500 motors and apparently they were glued on. How do I take off the basket without damaging the motor? thanks
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
anybody? I know its a noob question but I plan on taking them off today.
When I took the bent 15" basket off my RE SE 15 I just removed the machine screws and GENTLY pried the bask from the motor with a large Flathead screwdriver.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
I would do that but its completely glued on. Is there any appliant that will help deactivate the glue?
if the glue is really stuck on there, and a mallet - not hammer- Mallet doesnt work, use a heat gun where its mounted to the motor, and then hit with the mallet upwards
also acetone usually works as a glue de-activator, but heat works as good as acetone
alright thanks, ill give it a try. Shouldn't hurt the mag or anything right? or should i just apply a little to it and keep it from running down?
acetone dries almost instantly, as long as thinned out glue does not run in to the coil gap, your fine
I would try the heat gun first, or run a few passes with a blow torch if you have one
Alright ill try the blow torch first. if that doesnt work then ill try the acetone.
DD put some soft rubbery glue between the motor and basket to stop the basket 'ringing'
You just have to break the seal and it'll pop right off. Thin flathead, chisel, that kind of thing. The top-plate is steel so go for gold, it's pretty tough. If you're not re-using the baskets then you can get pretty crazy on them too.
10.x volts fo' life!
