Hunters21w Posted September 27, 2009 Report Posted September 27, 2009 Just got some DD 3500 motors and apparently they were glued on. How do I take off the basket without damaging the motor? thanks Quote 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Hunters21w Posted September 27, 2009 Author Report Posted September 27, 2009 anybody? I know its a noob question but I plan on taking them off today. Quote 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
wL<3bass Posted September 27, 2009 Report Posted September 27, 2009 When I took the bent 15" basket off my RE SE 15 I just removed the machine screws and GENTLY pried the bask from the motor with a large Flathead screwdriver. Quote Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
Hunters21w Posted September 27, 2009 Author Report Posted September 27, 2009 I would do that but its completely glued on. Is there any appliant that will help deactivate the glue? Quote 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Forevrbumpn Posted September 27, 2009 Report Posted September 27, 2009 if the glue is really stuck on there, and a mallet - not hammer- Mallet doesnt work, use a heat gun where its mounted to the motor, and then hit with the mallet upwards Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
Forevrbumpn Posted September 27, 2009 Report Posted September 27, 2009 also acetone usually works as a glue de-activator, but heat works as good as acetone Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
Hunters21w Posted September 27, 2009 Author Report Posted September 27, 2009 alright thanks, ill give it a try. Shouldn't hurt the mag or anything right? or should i just apply a little to it and keep it from running down? Quote 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Forevrbumpn Posted September 27, 2009 Report Posted September 27, 2009 acetone dries almost instantly, as long as thinned out glue does not run in to the coil gap, your fine I would try the heat gun first, or run a few passes with a blow torch if you have one Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
Hunters21w Posted September 27, 2009 Author Report Posted September 27, 2009 Alright ill try the blow torch first. if that doesnt work then ill try the acetone. Quote 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Boon Posted September 27, 2009 Report Posted September 27, 2009 DD put some soft rubbery glue between the motor and basket to stop the basket 'ringing' You just have to break the seal and it'll pop right off. Thin flathead, chisel, that kind of thing. The top-plate is steel so go for gold, it's pretty tough. If you're not re-using the baskets then you can get pretty crazy on them too. Quote 10.x volts fo' life!
