matt402 Posted September 27, 2009 Report Posted September 27, 2009 ' do u no the price on the lvl 4's 15's pm WCA Rusty for DC pricing.
justin smith Posted September 27, 2009 Report Posted September 27, 2009 pm WCA RUSTY justin smith 1996 mercury grand marquis 20'' bentchi b7 lexani n3000 245/35/20 cactus 5kw at 1ohm dcr(beast) 2 18'' btl's in a 14.15^ft wall tuned to 35hz with 210'' of port kicker zx650.4 componets in still the works 200amp motorcraft alt xs power d3100 (beast) kenwood ddx512 h.u. you mean my EX? the one I dumped? just remember every time you kiss her that i used to cum in her mouth and BTW your girl just called me.... pure pwnage
JPagan Posted September 27, 2009 Report Posted September 27, 2009 ' do u no the price on the lvl 4's 15's for the power you are running you would want the lvl 4 XLs, email rusty for prices, his email is [email protected] he usually replies pretty quick.
matt402 Posted September 27, 2009 Report Posted September 27, 2009 pm WCA RUSTY for the power you are running you would want the lvl 4 XLs, email rusty for prices, his email is [email protected] he usually replies pretty quick. joo both got posted .
Duece22 Posted September 27, 2009 Report Posted September 27, 2009 DC Lvl 5's 2008 Hummer H3 x2 Sundown Audio Nightshade V2 12s x1 Sundown Audio 3000D
biga48197 Posted September 27, 2009 Author Report Posted September 27, 2009 thanks for the email everyone
Torres Posted September 27, 2009 Report Posted September 27, 2009 Naw turn radio up on high volumes (not max tho). To find the true rms rating of a amp take a volt meter put the neg and pos on the speaker output or run speaker wire through the current clamp from the speaker output of the amp. From there you will get a read out. You take that read out and square it. Once you do that you divide that squared number by the ohm load you have your amp at. Once you divide that will give you your rms rating of that amp at that ohm load i hope you know that's not the true way to do it
eliassami5 Posted September 27, 2009 Report Posted September 27, 2009 Naw turn radio up on high volumes (not max tho). To find the true rms rating of a amp take a volt meter put the neg and pos on the speaker output or run speaker wire through the current clamp from the speaker output of the amp. From there you will get a read out. You take that read out and square it. Once you do that you divide that squared number by the ohm load you have your amp at. Once you divide that will give you your rms rating of that amp at that ohm load my amps have been tested with a volt/ current meter. The findings with volume on 30 (max is 35) are as follow... current output from amp was 56.2 you take that 56.2 and square it. You get 3158. Then you divide by the ohm load you have the amp at (mine was 1 ohm). So I did 3158/1=3158, which is my rms wattage at 1 ohm. Now I wont say that all PA amps can output like this one can but I have gotten good number off of different spl mics all btw 150 to 151.2 DB ur preaching to the choir and thats not the correct way to determine rms output. And no way in hell some power acoustics are putting out above their rated RMS, if anything it will be 1/4-1/3 less than the RMS wattage they are claiming. 91' Jeep Cherokee - The Heep Just Empty Every Pocket 96' Volvo 960 - The B◘x [sPL_4_U] HiFonics - Alpine Pioneer - Clarion Infinity - Kicker KnuKonceptz
ISO Posted September 27, 2009 Report Posted September 27, 2009 Here try reading this, http://www.stevemeadedesigns.com/board/ind...showtopic=23462 Screw the wattage I doubt your amps are seeing 1 ohm. Read post #5 and #6. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
pervitizm Posted September 27, 2009 Report Posted September 27, 2009 Good brands, and as others have said DC Sound should be on your list of subs to consider. I would probably also throw out there theses as well. I wouldn't mind playing with one of these myself. Incrimator Audio Warden Subwoofers 2007 Chevy Suburban LT1 Pioneer AVH 5700 DVD Diamond Audio D3 6 1/2 components Kicker 06ZX650.4 amp Kicker 06ZX2500.1 (x 2) DC Sound Lab Level 4 18's with Level 5 coils Autotek Mean Machine 400.1D (replaced) Soon to come: rims body kit flow master pipes Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it" Now feel free to go crawl back under that rock and leave this to the professionals....
